[ View Full Version Of This Page ]
2001 Stalling
All Forums » Chrysler PT Cruiser » 2001 Stalling
mshgturner
8/18/2007 5:13:16 PM
My 2001 and 1 stalls after driving at high speed.  It seems worse when it is hot out ... but still happens even when it is cool out. It occures after I have been running and comming to a stop.  Dosn't seem to happen even if I am sitting in traffic idleing.   The car runs fine at speed but stalls out when comming to a stop once you put the cluch in and the RMP drop below 1000.     Been having the issue for a while .. used to only happen occationally but now it is happening all of the time.. I haven't gotten any error codes before this week and have had it to the dealer several times and of course they can never find the problem  For the first time ever the check engine light came on with a 1391 error code... which I believe that it is not seeing the CAM or the crank signals all of the time....not sure if this is the issue or that when I stalled and the engine stoped.... that caused the code.    Any suggestions???
rjsmith
11/8/2007 5:31:30 PM
My 2003 PT limited 5 speed is doing the exact same thing I replaced the Cam sensor but that did'nt work.  I'm gonna change the Crank Sensor, PCV and EGR.
THIS IS A PROBLEM CHRYSLER NEEDS TO ADDRESS!!!
THERE ARE SO MANY OF US OUT HERE WITH THE SAME ISSUE IT MUST BE A COMMON PROBLEM.
C'MON CHRYSLER DO SOMETHING!
I USED TO LOVE MY PT NOW I HATE IT...
moe
11/8/2007 6:07:27 PM
yes thats the code interm.loss of cam or crank sensor.i would put the crank sensor in only after you check the wiring.do a wiggle test on the harness.if nothing replace the sensor.the older pcms can't tell which sensor is bad thats why it throws the code for both.turn your ign key on and off  three times and leave the key on after third time and read the codes it says on the dash cluster...p0? moe
rjsmith
11/19/2007 6:45:15 PM
I don't get any sensor codes with the three time start/off key method.
I just completed a wiring check and a replacement of both the crank sensor and the cam sensor.  The cam sensor did not include a new magnet however.  The crank sensor was a tight fit in the block so I might try a mopar one, but I doubt it will do much good.
After driving at speed and pushing in the clutch the PT still drops RPMs to 500 and the stalls about 1/2 the time.
I'm desparate, any more ideas?
CHRYSLER TECH
11/19/2007 10:20:44 PM
have u taken it to the dealer to have the latest software installed on the computers?
moe
11/20/2007 5:58:28 AM
have you looked at your throttle body? could just need to be cleaned out.moe
WYOCHIMNEYSWEEP
11/20/2007 7:03:47 AM
iac sticking?
rjsmith
11/20/2007 5:13:31 PM
I fear I'm going to have to check it into the dealer.
I've had a bad and expensive history with our local dealers.  It took them four attempts to fix a simple fan relay and they never have fixed the squeaking belt.  I just can't afford for them to screw me with 1000s of dollars in repair costs.
What is the "iac"?
I'll clean the throttle body tonight.
Should the cam sensor and crank sensor be coated in oil?  both were when I removed them.
Thanks for all the feedback guys.
rjsmith
11/20/2007 5:23:41 PM
Oh one more thing when I put in the crank sensor, it was in the front of the block and very difficult to get in and out.  It seemed like it was slightly too large.  I have since purchased a Mopar part.
rjsmith
11/20/2007 7:18:12 PM
Here is a picture of the crank sensor I just removed.  Note the oil, this was only in the PT for two days.  The same oil is on the cam sensor, is this normal?
I've heard of wildly high oil pressure on some PTs I did'nt know if that might be the cause, but then again oil on the sensors may be normal.
Thanks for what ever imput you guys have.
Rich
rjsmith
11/20/2007 7:19:04 PM
rjsmith
11/23/2007 6:52:07 AM
Anyone ever change one of these?  Do they always have oil on them?
pulpjava
9/15/2008 5:23:02 AM
This sounds strange, but when I had this problem, I disconnected the battery for a day. It seemed to have reset the computer or something, and the problem went away. I wrote about it here:
http://www.chryslerforum.com/m_20749/mpage_1/key_/tm.htm#20749
I''d love to know if a similar approach helped you.
-Cameron McKenzie
chiefpt
9/30/2008 7:54:08 AM
2003 PT Cruiser 5 spd Stalled at stop and RMP drop to 500, I fixed the problem
1- replaced cam and crank sensors (@ $60.00 for both)
2- replaced spart plug Champion #7570 (@ $20.00)
3- replaced mopar spart plug wires
4- cleaned throttle body
5- spay using CRC electronic cleaner (@ $6.00) Intake Air Temperature sensor.
Gook Luck !
Previous Thread: Squeaky Steering
Next Thread:   noise possibly in engine? sounds like motorcycle?
Related Threads
Return to the Chrysler Forum home page - Archive Home
