[ View Full Version Of This Page ]
2002 300M CEL codes
All Forums » 300M, Concorde, LHS, New Yorker » 2002 300M CEL codes
Netjunky
7/3/2007 1:51:12 PM
Car-2002 300M 3.5L HO-My engine has been running rough for awhile now at curb idle...the RPM's don't move very much just the engine feels like it is misfiring. Then 2 wks ago the CEL came on with a P0300 code-Multiple engine misfire. So I reset the code by disconnecting the battery for 30 min. Codes were gone, but the engine was still running rough. Then 1 wk ago I got a P0133 code - 02 sensor 1/1 slow response. The CEL went out on it's own after a few starts. Now today with the CEL back on and the engine running rougher I also get the code P0172 Fuel system 1/1 Rich along with the P0133 code. My worry is that if I replace the O2 sensor this will not solve my problem and that the problem is a bigger one which caused the initial P0300 fault and is now causing the O2 sensor to crap out. Any ideas?
CHRYSLER TECH
7/3/2007 6:18:37 PM
the upstream o2 controls how much fuel is injected into the system. Replace the 02 to start and do not disconnect the batt. That is the worst thing  u can do as for as trying to fig out whats wrong and if it fixed it.
If u correct the issue the computer will rerun the same test that turned on the CEL and if it passes 3 times under the same conditions as the CEL was turned on the computer will turn it off for u and U know its fixed with out guessing.  So  replace the 02 sensor  and for good measure replace the plugs with champion plugs factory plugs  nothing else.
Netjunky
7/6/2007 8:25:34 PM
Thanks for the reply! I have bought a new O2 sensor and will replace it....I will replace the driver side soon as well just to be sure. I'll post back here with the results.
Previous Thread: Please Help! 94 LHS
Next Thread:   2001 LHS electrical problem
Related Threads
Return to the Chrysler Forum home page - Archive Home
