[ View Full Version Of This Page ]
2007 Pacifica
All Forums » Chrysler Pacifica » 2007 Pacifica
SDHUSKER
11/4/2007 7:51:31 AM
As the new owner of a 2007 Pacifica with the 4.0L engine I have been unable to find an engine block heater.  The dealership says there are none available even though my manual states that use of an engine block heater is recommended for cold climates and to check with the dealer for installation.  Anyone heard of this or have one installed?
silenthunter
11/4/2007 8:39:32 AM
I have one installed on mine.  $40 from the dealer.
jamie1
11/4/2007 8:47:36 AM
I would say you were dealing with a lazy or inexperienced parts person. The 4.0L has an available block heater as do ALL Chrysler cars.
SDHUSKER
11/4/2007 1:30:03 PM
S. Hunter and Jamie, do you have a parts number?  Was your heaters installed after market or come installed on the vehicle?
jamie1
11/4/2007 1:55:38 PM
Mine was a factory installed block heater. I will see if I can get a part number on Monday.
jamie1
11/5/2007 5:51:25 PM
part# 4609325AB
silenthunter
11/5/2007 6:45:46 PM
Mine was factory installed....sorry no part #.
SDHUSKER
11/6/2007 4:56:51 AM
Thanks Jamie.  I'll check with the local dealer parts department.  Will let you know the outcome.
SDHUSKER
11/6/2007 7:49:57 AM
To:  Jamie1
Well Jamie I had them check the parts number and sure enough there is a "replacement" element for the block heater for $49.95.  Then one must buy the cord for $57, and pay for about $150 labor to install.  What a joke.
jamie1
11/7/2007 6:18:58 AM
I thought that part # was for a block heater kit. [heater and cord] Which is always cheaper then the cord and heater. Might not be available for the Pac. The labour should be less then 1hr. ,as the coolant does not have to drained and a core plug does not have to be removed. The heater goes into a precast pocket in the block. I personally have not used a block heater in about 10 years. I park in my garage at home. Even on the coldest nights of -35C[-31F] my garage is only about -5C[23F]. At work I do not have access to a plug in and have never had a problem starting my cars even after 9 hours of sitting.
Previous Thread: 2007/2008 Pacifica RAH radio
Next Thread:   CORRECT OIL WEIGHT
Related Threads
Return to the Chrysler Forum home page - Archive Home
