help on ' timing probably one tooth off'
Old Jul 28, 2011 | 08:29 PM
jly2258's Avatar
Default help on ' timing probably one tooth off'
I am in the middle of the timing belt, water pump, thermostat replacement on the 2000 300M: I got the new belt on, all 3 marks lining up and when I tighten down the tensioner bolts (haven't released the cotter pin yet) both the cam timing marks moved a tooth to the left. I started over and moved them back to where I started (crank mark stayed at tdc). I can hand tighten quite a bit and have them stay, but they seem to stray with the tensioner tightened down. Is there a guideline for how to check how much tension should be on the belt before pulling the pin? I can't get a torque wrench in there either so the 250 in/lbs. doesn't help.
Any thoughts appeciated.
Old Jul 28, 2011 | 11:07 PM
release it then turn the crank until all the marks align back up if they are then u are good.
jly2258
Aug 6, 2011 07:15 AM
deedee
Jan 15, 2009 07:15 PM
BMFSRT8
Mar 3, 2006 02:03 PM
Rico
Nov 14, 2005 07:17 PM
redriderbob
Dec 11, 2004 05:11 AM
