1999 Chrsyler LHS AC not cold
Bought another new fuse today & plugged it in and ran the AC.The AC worked!! the Radiator high fan fuse did not burn.Both fan started to turn immediately once i turn on the AC.Ran it for a while and the high fan relay fuse did not burn.However noticed that the passenger side fan was turning faster than the fan on the Driver side.Is it normal?
Anyway i drove it the whole day with the AC working fine so far )
Did a check on the fuse boxes in the engine compartment and found that the fuse which is for the Radiator high fan was burnt/blown.Had it swopped and i turned the engine on and tried and turn on the AC.The AC worked perfect and had cold air and noticed that the one of radiator fan started to turn continuously !!! But after running the AC for about 5 mins it was not cold again but had hot air and the radiator fan also had stopped. Took a look at the same fuse that had burnt earlier and found out it had burnt/blown out again!!!
So what could have caused the fuse to overload and burnt??
Lukeluk
01-09-2011 07:10 AM
bigrobot
06-26-2007 09:44 AM
