apply parking brake put car in neutral with car off (this helps with next step)
ok remove center console (wood trim on mine) or the thing around the stereo
unplug the traction control and cigarette light
pull plastic completely away and unscrew headunit (4 screws)
pull headunit out until u can reach antenna wire that is in the back of headunit
unplug antenna then plug it back in to reset headunit
put back together (remember cigarette lighter and TCS plugs)
if this doesnt work then idk...
___________________________________________
i dont fully understand this you simply switch to it and click the reset button
finally this one. Replace the fuse and get back to me... my mechanic couldnt find the problem he pulled my engine compartment open enough and checked all relays but first he checked the fuse and the fuse was fine. we took it to the dealership they replaced the fuse and it has worked ever since. mine didnt work for 6 months before this was found out.
problem? fans were rewired after a collision and my personal mechanic didnt cover the wires correctly and so the fans short circuited the fuse for the compressor
fix? replace fuse and they said replace the fans but i havent yet and its been a few months and it still works they told me if it ever short circuits again then to replace the fuse and it'll work for 5 minutes or 5 years theres no telling without new fans.
prepared? I have 4 fuses in my car for it.
