2001 Chrysler LHS
ATC Control panel. No need to buy new if you are handy. These are nototious for solder joints that fail and can easily be repaired. Or there is a guy on ebay thet sells repaired ones for decent $$
http://300mclub.org/forums/viewtopic.php?f=10&t=12363
That "seperate issue" is often called the "light show" common to LH cars.
Roll the "dimmer" wheel full teavel a few times and set it just below max brilliance. If it still occurs, there was a "fix" when these cars were new.
Disconnect/reconnect the wire harness at the headlight switch a few times. Finish off with a little dielectric grease on the contacts.
Recommend you do not waste any more time here at this site. If you want real help visit www.300mclub.org we welcome all espically LH cars with real help and good advice
Hippoman123
10-21-2012 06:54 AM
FauxGiovanni
10-13-2010 07:08 PM
