View Poll Results: Rear timing cover bolt snap by itself shortly after timing kit/water pump work????
Bad install of timing kit/ water pump?
0%
Timing belt tensioner loose?
0%
Rear inner timing cover bolt torqued by mistake?
0%
Been ripped off?
0%
Could engine jump time missing a rear timing cover bolt???
0%
Could a rear timing cover bolts snap after 51,000 MI?
0%
Could it be that the repair shop was seeking MORE money for more repairs?
0%
Human error?
0%
Cause of snapped off bolt???????
0%
Engine not sycronized after timing kit install?
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
2002 3.5L DOC DTC P0016 shortly after timing kit/water pump install
Old 11-22-2014, 05:56 AM
nonhemi1959's Avatar
Default 2002 3.5L DOC DTC P0016 shortly after timing kit/water pump install
FACT OR FICTION??????? 2002 3.5L DOC with less than 51,000 miles that ran very strong. The engine was non problematic until recently. The water pump started to leak with the change of colder weather. So I brought it to a repair shop and the water pump and timing kit were replaced. Quality parts were installed. A short time later (about 250 miles) The check engine light with DTC P0016 ( Crankshaft/camshaft timing misalignment/ out of synchronize) appeared. The engine would idle just fine, but during acceleration the engine would run badly. I brought it back to the repair shop about 3 weeks after the work was done, only driving it very little after the diagnostic trouble code had appeared.... I believed that the belt tensioner was possibly defective OR something wasn't tightened properly. I was told that a rear (inner) timing cover bolt broke off by itself. The shop claims to have never touched or torqued that bolt although it is about 4 inches away from the water pump bolts. The bolt had broken off by some mystery and made the timing jump, I am told by the repair shop! Now it appears to me a mystery that this bolt would snap off all by itself after nearly 51,000 miles and this work was recently done by the repair shop!!! The bolt is steel and the timing cover housing is aluminum as well as the engine block that it is bolted to. Has anyone ever heard of this happening??? Have I been fandangled???
Old 11-22-2014, 07:18 AM
FIREM's Avatar
I would call B S on this one. Sounds like the tensioner bolt has been broken. Having worked on many many 3.5's and active on 4 forums dealing with LH cars, this is the first time one has mysteriously snapped on its own.......
More than one person has miss installed or stripped that bolt.
Gasguzziler
11-26-2012 12:39 AM
Sebring Scot
07-17-2012 06:55 AM
daicon0
07-08-2012 11:44 PM
dmbeale
15
11-24-2010 06:26 PM
Minus5252
01-19-2009 10:26 AM
Quick Reply: 2002 3.5L DOC DTC P0016 shortly after timing kit/water pump install
