Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Past Chrysler Models > 300M, Concorde, LHS, New Yorker
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 04-08-2011, 10:35 AM
Default 2004 Concorde ECM/PCM Location
My mechanic has confirmed that I need a replacement ECM/PCM module, and basically told me I could save money by purchasing it from their supplier myself and replacing it myself.
That said, where can I find it and how do I remove it? I'm ignorant about most things car repair, but follow directions well.
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 04-08-2011, 04:42 PM
Send a message via AIM to CHRYSLER TECH Send a message via Yahoo to CHRYSLER TECH
under the driver side radiator support
The PCM engine control strategy prevents reduced idle speeds until after the engine operates for 320 km (200 miles). If the PCM is replaced after 320 km (200 miles) of usage, update the mileage and vehicle identification number (VIN) in the new PCM. Use the DRBIII® scan tool to change the mileage and VIN in the PCM. If this step is not done a diagnostic trouble code (DTC) may be set and SKIM must be done or car will not start if it is a SKIM equipped car. If a SKIM car you must do a secret key transfer also. Refer to the appropriate Powertrain Diagnostic Manual and the DRBIII® scan tool.
To avoid possible voltage spike damage to PCM, ignition key must be off, and the negative battery cable must be disconnected before unplugging the PCM connectors. Note radio programs.
Unbolt the washer bottle filler neck and reposition.
Disconnect the 4 PCM electrical connector.
Reposition wiring harness out of the way (NGC CONNECTORS).
Remove the 3 fasteners from PCM mounting (NGC MOUNTING).
Remove PCM (NGC CONTROLLER).
__________________
Dealer trained Tech 15 years Now Proud Owner operator Kevin's Mobile Repair in ATLANTA. Repairing Chrysler,Dodge and Jeep
KKeller608@aol.com
http://kevinsmobilerepair.com
Tags
04, 2000, 300m, chrysle, chrysler, concorde, control, default, ecm, ecmpcm, engine, location, module, pcm, remove
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
