1999 Concorde disc brakes
Old 11-08-2010, 09:31 AM
JohnC136's Avatar
Default 1999 Concorde disc brakes
Replaced front disc pads...now pedal goes almost to the floor to stop the car. No leaks, fluid appears OK and never went below normal. Pumping the pedal does not raise it at all.
Sounds like a master cylinder, but has anyone heard of this? I've been repairing brakes for years and never heard of a master cylinder being damaged after pressing the caliper piston back into the housing.
Thanks for any help on this.
Old 11-08-2010, 09:07 PM
what are the steps U did for replacing the pads?
Old 11-09-2010, 01:19 PM
JohnC136's Avatar
1.Removed two bolts
2.Lifted off caliper and removed old pads
3.Used C-clamp to press piston back into caliper...siphoned out extra fluid from master cylinder.
4. Installed new pads; mounted caliper and clips
5. Pumped brakes - OK after driver side; symptoms appeared after passenger side.
Pretty straight forward...hope you have some ideas on this.
Old 11-10-2010, 09:36 AM
yeah u did it right try bleeding the brakes rear first then front
Old 11-15-2010, 10:49 AM
JohnC136's Avatar
That did it...not sure how I managed to get air into the system, but I'm good now. Anyway, thanks for your advice ...I certainly appreciate it.
Old 11-15-2010, 03:00 PM
welcome
Brendan Tracy
09-04-2014 10:54 AM
lambo-concorde
9
10-08-2012 01:08 PM
rhinocruiser
08-22-2011 04:10 AM
goco
07-12-2011 11:38 AM
bigdpeter2
09-03-2010 05:23 PM
Quick Reply: 1999 Concorde disc brakes
