2002 300M - P1776 code, valve body replaced
Hello,
recently I bought this nice 300M from guy who was desperate because of
limp mode stilll going on. He replaced valve body, solenoid packs, remanufactured transmission, changed PCM and still nothing. The limp mode happens after about 15 mins of driving, mostly when you get over 45 mph for some time and then slowing down for junction.
Except code
P1776 there were also
P1790-FAULT IMMEDIATELY AFTER SHIFT
P0750-LR Solenoid Circuit
P0755-2/4 Solenoid Circuit
Do you think it is some electrical problem?
thanks!
Except code
thanks!
I have new knowledge, when I cut off ABS, the transmission starts to behave differently, it gears to 2. gear when I am idling on brake or cant gear when I am moving on. But even when I plug again ABS it stays behaving like that until I leave it in piece for a while.
still no luck, i spent 1000 euro for new pcm, clutches, harness check. I have another gearbox, i try to replace valve body and sol. pack from it one more, if it doesnt help i will replace whole transmission. Hope you will have more luck. Cheers
I don't want to replace the gearbox
The reason This issue happens, is because your torque converter is full of junk, and all that debris is transferred to the cooler. Replacing the cooler and converter sounds like a plan, but all that junk has been transferred back and forth thru the transmission, and as a result, even after the fact, the system is contaminated.
littlebanks3
05-07-2011 11:53 AM
Lesley1020
02-20-2009 11:08 PM
iabeancounter
02-28-2008 12:42 PM
