Battery problems
Old Mar 22, 2012 | 01:18 PM
chrysler chick's Avatar
Unhappy Battery problems
Hello, iM having a issue with my car, i went to go leave from work couple days ago and i turned the key over and nothing so i called someone for a jump, well that wasent the case, once the car was jumped it automatically stalled out. jumped it one more time and it started but everything was flickering in the car, all the gauge lights were on and it acted like it wanted to stal again so i turned it off ..re tried to start it and nothing AGAIN!!!!
So make a long story short. there was a code reading P0563 (High voltage) so i went got a brand new battery put it in. It finally did START buttttt..now upon starting it and letting the care idle it feels like it wants to stall out, when i drove it on the road from one block and back it seemed fine. the car just running really ruff after the battery change/
Any suggestions??? or what might have caused this?
Old Mar 22, 2012 | 03:55 PM
Replace your battery it has low amps.
Old Mar 23, 2012 | 07:32 AM
i did replace the battery, this all started after it was replaced?
Old Apr 8, 2012 | 11:42 PM
Corys300M's Avatar
When i replaced my battery there was a fusible link from the positive side that had rotted away to the point where only a few strands held the wire together. The wire sits directly under the air cleaner assembly. Not sure if this is the problem your having but it may be worth the look.
darlon
Jan 16, 2012 05:00 PM
alpine
Dec 27, 2011 06:00 PM
tdcobb7
Sep 11, 2007 01:09 PM
jmm
Aug 31, 2006 08:05 PM
