Code P0430 "Catalyst System Low Efficiency Bank 2"
Ok, i just got this car, and obviously this code is stopping me from getting the car smogged. the dealer i bought it from has his mechanic on the problem.
We have figured out that the code is caused by the downstream O2 sensor, probably due to faulty catalytic converter.
So i have a couple questions:
1. Which side of the car is bank 2? Drivers? Passenger?
2. He replaced the catalytic converter on the passengers side, and after a few miles, the engine light popped back up with the same P0430 code. Did the correct cat get replaced?
3. If it was the correct cat, i guess the next course of action would be to replace the offending o2 sensor.
4. If that doesn't work, what else could be causing the issue here?
