Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Past Chrysler Models > 300M, Concorde, LHS, New Yorker
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 07-13-2011, 01:46 PM
Default Concorde cooling system routing diagram?
I really need a diagram of the cooling system showing all the hoses and connections.
I have a 2002 Concorde with the 3.5 liter engine that is boiling over even though the temp gauge never goes beyond the 3/4 mark.
I bought this car from a private dealer who I thought was giving me a good deal. What I found out later is that after it has been running for a while and is brought up to highway speeds, it starts to boil over (the test drives were too short and quick to discover this issue). I didn't have time to do anything but the simplest diagnosis so I brought it to mechanic. He tested everything and replaced the water pump, thermostat, radiator, coolant reservoir and cap and back flushed the heater core. These items were replaced one at a time after the previous "fix" didn't fix it. After all of this the problem remained. I then brought the car to the local Chrysler dealer to see what they could do. A $1000 later after another new water pump, timing belt, coolant reservoir cap and thermostat, the problem remained. They then did what they called a "clear hose test" which supposedly checks the coolant passages throughout the engine. They told me that the coolant passages in the block were plugged and a rebuild or new engine was required (probably due to the dealer adding something to stop leaks). So I bought myself a rebuilt long block and swapped the engine out. THE SAME PROBLEM REMAINS!! While I was putting the new engine in, it occurred to me that the routing of the coolant hoses on the original engine seemed odd. There is a four-way connection at the rear of the engine that connects the heater core, the coolant reservoir, the thermostat housing and the PCV valve together. Why would the PCV valve, which is attached directly to the rear of the upper intake manifold, have a connection to the cooling system?!?! I think what may be happening is that hot engine gases/exhaust are being pumped into the coolant and causing it to boil over. So $4000 of parts and repairs later and I am right back where I started.
Sorry for the long post but there has been a lot covered trying to resolve this problem and I am out of ideas.
P.S. The fans are working properly.
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 07-19-2011, 08:12 PM
wow. Sorry I don't have the knowledge of this car's coolant system yet. Did fixing the PVC path fix the issue?
Old 07-20-2011, 12:37 PM
Default Problem was coolant reservoir
The plumbing is/was correct. The coolant creates a "jacket" around the PCV line to keep it from freezing in the winter. The actual problem was (another) faulty coolant reservoir. There was a leak at a seam between the chambers that wouldn't allow pressure to build up and keep the coolant from boiling.
Old 07-20-2011, 01:18 PM
Just a note....Be careful with these, ...The 2.7 and 3.5 are NOT IDENTICAL, although the bottles physically look the same.
__________________
Professional Mechanic since 1985, Chrysler Dealership Technician since 1999.
We aren't ALL thieves, We're Just trying to make a living like everyone else , So Have A Heart.
If You wanted Dealership Service, You wouldnt Go To "Discount Quik Lube" , So why did you Walk into a dealership Expecting QUIK LUBE PRICING????
Ma'am, It costs so much money, because ...I CAN, And you CANNOT, And It matters Not to Me, Because I HAVE A RIDE HOME.
3/36 Does not mean 3 years and a day, or 36,001
Tags
300, 300m, 35, boils, chrysler, collant, concorde, coolant, cooling, diagram, engine, radiator, reservoir, schematics, system
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
