I'm sure there have been hundreds of posts on this but I'm a little stuck.
My Concorde started blowing hardly warm air. After some investigation I decided to change the thermostat, stopped it back up with antifreeze/coolant and off I went, still the same problem.
I decided it was time for a coolant flush anyway because I've not had one done in the 4 years I've had the car (and who knows before that) so now I'm pretty sure there is no air bubble in the system (unless they messed up).
It's still getting barely warm air through the vents.
The hose coming out the left of the thermostat housing was hot so I'm sure it's flowing.
Open to what else to systematically check/try/change to try and get some heat back.
Thanks,
Nigel
make sure the blend air door is moving when u change the temp setting if it is then u have a clogged up heater core.
__________________
Dealer trained Tech 15 years Now Proud Owner operator Kevin's Mobile Repair in ATLANTA. Repairing Chrysler,Dodge and Jeep KKeller608@aol.com http://kevinsmobilerepair.com
