po344 cam and crank sensors have been changed
Old 10-07-2011, 11:01 PM
markush's Avatar
Default po344 cam and crank sensors have been changed
2004 Concorde LXI I've been getting this code for a long while. I replaced the the Camshaft sensor last fall (the car was not driven through the spring/summer and is my winter car). The only thing that changed when the sensor was changed is that it no longer stalls on me when the CEL comes on with this code...it used to stall driving down the road and not restart right away...that really sucked.
Anyway, I just got around to changing the crankshaft sensor...and that made no difference at all...So both sensors have been changed now and I'm still getting the code and going into limp mode.
What's next?
I haven't yet taken advantage of the recall to update the computer to prevent catalytic converter damage when driving in limp mode...I can't imaging that update would stop the code from appearing...would it?
Old 10-08-2011, 10:06 AM
that update is for when there is nothing wrong with the cam sensor and u still get a check engine light and go into limp in mode.
Put a mopar cam sensor in
Old 10-08-2011, 11:05 AM
markush's Avatar
If that's the case that could be my problem since the sensor was changed already...no? I'll get the update then try the Mopar branded sensor...thanks.
Old 10-08-2011, 06:54 PM
aftermarket sensor are known to cause issues
Old 01-18-2012, 08:01 PM
thebirdman's Avatar
Default concorde won't start
2004 concorde, after a short drive, say 30 miles, stop car to go into a store, come back out, car won't start. Motor turns over, starts after a couple mins. I have changed the crank shaft and cam shaft sensor twice. Runs good for a couple weeks, then here we are again. HELP!!!!
Jason1969
03-17-2015 12:21 PM
beast39
03-09-2011 08:47 PM
kazeck23
02-16-2011 10:05 AM
donnyohs
22
07-17-2009 03:19 PM
Quick Reply: po344 cam and crank sensors have been changed
