Noise Until 1500 RPM
Old 02-14-2015, 03:42 PM
mschaefe's Avatar
Default Noise Until 1500 RPM
I have a 2000 LHS with a little over 90,000 miles. Car was a gift from my grandfather. There's been a couple of things that I've had to fix already. The thing that I can't figure out on my own is this sound that I hear while driving under 1500 RPMs. When I first start the car there is no sound, as soon as I step on the gas there's a sound and the sound will be constant until I surpass 1500 RPMs. When I'm slowing down the sound won't occur unless I still have my foot on the gas a little bit. If I surpass 1500 RPMs and then let the car coast you don't hear the sound until I step on the gas under 1500 RPMs. The sound is hard to describe but to me it sounds like a bad bearing somewhere or like the engine is just running rough until I go past 1500 RPMs. I'm taking my car in Monday for some routine 90,000 mile maintenance and I'm going to have the mechanic try to figure it out but I would like an idea of what I might be dealing with before I take it in. Let me know if you need any other information.
Old 02-16-2015, 06:04 PM
mschaefe's Avatar
Default Update
My AC compressor ceased and had it replaced. I also had the V belt, serpentine belt, idler pulley, and tensioner pulley replaced. The previous noise is gone however, no I have a constant sound that sounds like a clicking at idle and like a weed eater when I'm accelerating. I've tried to trace the sound and it sounds like it might be coming from the front of the engine. Could this be something with the timing belt or any of the timing components? Car is at 90,000 miles, may be time to change the timing belt? Any help would be appreciated.
Old 02-17-2015, 03:26 PM
FIREM's Avatar
You are overdue for a timing belt replacement. 7yrs/100k interval and if it fails you will bend valves.
Water pump, timing belt idler bearing and belt should all be replaced. Whie the front is apart check the bearings for the belt idlers previously replaced.
http://300mclub.org/forums/viewtopic...g+belt+failure
Check that the hood release cable is properly routed and not to close to the alternator. Common cause of "weed eater" noise up front.
John Jarman
11-07-2012 08:53 AM
aerospac3
07-15-2012 10:55 AM
gflu
05-06-2012 11:25 PM
jwms
07-03-2007 08:13 AM
Turbochump
01-31-2007 08:19 AM
Quick Reply: Noise Until 1500 RPM
