Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Past Chrysler Models > 300M, Concorde, LHS, New Yorker
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 11-06-2011, 12:31 PM
Default odd heating issue
99 LHS just started something new. Start the car up for the warm up get car is cold, as soon as you step on the gas to go warm air begins to flow when you stop at a light cold air comes out. My ford never had a heat problem it had a defrost floor problem which was attributed to a broken vacuum hose. I have not looked at the vacuum diagram to see if this could be an issue with the chyrsler. Any ideas?
Keith
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 11-06-2011, 05:41 PM
Send a message via AIM to CHRYSLER TECH Send a message via Yahoo to CHRYSLER TECH
check for low coolant this system will be a bit different u wil need to add water or coolant into the rad cap until it is at the vary top.
__________________
Dealer trained Tech 15 years Now Proud Owner operator Kevin's Mobile Repair in ATLANTA. Repairing Chrysler,Dodge and Jeep
KKeller608@aol.com
http://kevinsmobilerepair.com
Old 11-06-2011, 06:12 PM
so how big a deal is it to change a heater core in this car, th reason I ask is my wife says she smells anti freeze once in a while and then the hot cold issue, I still have to check some external hoses to make sure thats all good.
Keith
Old 11-06-2011, 09:05 PM
whole dash comes out then the HVAC box comes out to get to the heater core.
__________________
KKeller608@aol.com
Old 11-07-2011, 07:48 AM
were these cars prone to head gasket issue, I've had no overheating but am curious.
Old 11-07-2011, 03:10 PM
not many
__________________
KKeller608@aol.com
Old 11-07-2011, 05:05 PM
TNtech's Avatar
How far up is your temp gauge getting?
__________________
Chrysler-Jeep-Dodge Technician
Electrical & Driveablity
Crossfire
Old 11-07-2011, 05:52 PM
i found the coolant reservoir low, so i refilled thened warmed up the car awent for a ride, heating is working just fine, temp gauge stays below halfway, found no signs of a leak anywhere, checked all hoses, radiator, saw no signs of leaks in the water pump area. After I shut the car off within about 5 minutes the coolant in the reservoir was gurgling. at first it was spilling out the over flow.
My thoughts would be a bad pressure cap or a sticking thermostat, however I would think if it were a thermostat I wouldnt have a gauge reading where it is, any ideas?
Old 11-07-2011, 10:56 PM
is not the low coolant what I had talked about yesterday?
__________________
KKeller608@aol.com
Old 11-08-2011, 06:19 AM
yes, that is what i found, what i'm trying to determine is why its low on coolant, when the engine is running all seems good when the resevoir is topped off, when you shut off the engine that is when apparently the coolant boils and overflows from the fill tank, if a head gasket is blown then I would think you get one od 2 reactions, one would be excessive steam from the exhaust, the other would be heat from the combustion chamber blowing back into the coolant system and boiling the coolant out. The problem is I cant figure out why this would only happen when the car is shut off. Thats why I was thinking possible pressure cap. I not sure on the thermostat, because it would seem that the heater wouldnt work at all( depending on where they put the heater in the system) if it were stuck.
Tags
99, heaater, heat, lhs
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
