Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Past Chrysler Models > 300M, Concorde, LHS, New Yorker
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 08-03-2011, 07:58 PM
Default p0303, and p0203
I know the codes, I started with the obvious, sprk plugs, they were worn to the point that the gap was about .100. I'm thinking this might be an easy one. so i replaced the plugs, and cleared the codes. Drove it about 30 miles when the engine light started flashing. Stopped and checked codes again, same 2 codes have returned. So as far as the 0303 code I am going to move the coils and see if the problem follows the coil. If so no problem. As far as the 0203 injector open or shorted, wiring looks good no obvious breaks, in the bmw motorcycle world first thing we do is check for voltage to the injector then a pressurized fuel system clean which most of the time solves the issue.
does this sound like i'm on the right track, has anyone experienced this
keith
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 08-03-2011, 09:21 PM
Send a message via AIM to CHRYSLER TECH Send a message via Yahoo to CHRYSLER TECH
the 303 is the result of the 203 work on the 203 and the 303 will go away
__________________
Dealer trained Tech 15 years Now Proud Owner operator Kevin's Mobile Repair in ATLANTA. Repairing Chrysler,Dodge and Jeep
KKeller608@aol.com
http://kevinsmobilerepair.com
Old 08-04-2011, 06:23 AM
so should I pull the plenum and then check the injector after verifying the voltage at the connector?
Old 08-04-2011, 08:37 AM
unplug it while its running see if the engine changes any then check for power and a ground pulse
__________________
KKeller608@aol.com
Old 08-06-2011, 07:32 PM
Unhappy still there 0203 and 0303
quick over view, , while driving at interstate speed the engine began to shudder, check engine started flashing, codes were 0203 and 0303, replaced all spark plugs as they were severely worn, car ran great for 30 miles, codes returned. car will run smooth for awhile then shudder for awhile.
next step was a pressure cleaning of the fuel injectors, car ran good for about 10 miles, then again, next step was to move the coil to cylider 2 and see if the fault followed the coil, it did not. my next step is to do as Kevin suggested, I can fairly easily check for voltage and ground pulse to the number 3 cylinder, if that is good, the only thing left is the injector.
I'm waiting on the injector, because to get to it you have to remove the intake plenum. TWO questions.
1 has anyone experienced this problem?
2 is the plenum going to dish out any surprises when I remove it?
any suggestion?
Keith
Old 08-08-2011, 07:17 PM
Default solved
found 12 volts at the injector and the ground side was pulsing, removed the injector and tested the pintle with a momentary button, couldnt hear anything then the pintle strted moving then quit again, replaced the injector and cleared code, everything works fine, problem solved, thanks Kevin
Keith
Old 08-08-2011, 08:53 PM
welcome
__________________
KKeller608@aol.com
Tags
0203, 0303, 2000, 300m, 99, chrysler, code, codes, concorde, fault, jeep, lhs, p0203, p0303, po303
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
