Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Past Chrysler Models > 300M, Concorde, LHS, New Yorker
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 05-23-2011, 06:23 PM
Default Putting back the Valve body on the transmission - 2004 Concorde lxi
Hi everyone. I just replaced both the solenoid pack and the transmission range sensor and am having trouble putting back the valve body. I dont know where the overdrive and underdrive pistons with the springs go. Everything is ready to go back in but I need to know where these two pistons go. Does anyone have a dryagram or something? Please help.
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 05-23-2011, 06:31 PM
The pistons should be interchangeable, the face goes up the spring goes into the Hollow portion of the piston. They fit into the holes in the right front corner of the case, above the valvebody.
__________________
Professional Mechanic since 1985, Chrysler Dealership Technician since 1999.
We aren't ALL thieves, We're Just trying to make a living like everyone else , So Have A Heart.
If You wanted Dealership Service, You wouldnt Go To "Discount Quik Lube" , So why did you Walk into a dealership Expecting QUIK LUBE PRICING????
Ma'am, It costs so much money, because ...I CAN, And you CANNOT, And It matters Not to Me, Because I HAVE A RIDE HOME.
3/36 Does not mean 3 years and a day, or 36,001
Old 05-23-2011, 06:35 PM
Just a hint....
A slip of cardboard to hold them up in the case.....Put the V/B in position, catch the front bolts, and pull the cardboard straight out. finish starting and tightening the bolts.
__________________
Old 05-23-2011, 06:39 PM
HI, thank you for your answer. Are you talking about the two identical holes in the body? One side looks like an intake and the other like what the piston would push against. I'm confused because when I removed the V/B one of the pistons was still attached to an area (a round area that fits the piston perfectly) on the top of the inside body near where the soneloid pack goes into. I could be wrong (tha's why I'm asking) but would only one piston go into one of the holes you told me about (and which one?) and the other to the other area near the solenoid pack? This is a little bit of work and I just wanted to make sure it goes back in right. thank you again.
Old 05-23-2011, 06:54 PM
Default still needs help
Old 05-23-2011, 07:12 PM
Ok...There aRE 3 of them...Its sort of a wierd angle since the picture is with the unit out of the car, but it should be useable.
Accumulator pistons
1 - OVERDRIVE ACCUMULATOR LOCATION
2 - UNDERDRIVE ACCUMULATOR LOCATION
3 - LOW/REVERSE ACCUMULATOR
__________________
Old 05-23-2011, 07:24 PM
Default now I'm even more confused. Tow pistons came out.
HI, you said there are 3 pistons, but only two came out. This is a 2004 Chrysler concorde lxi. 42LE type transmission. is that what you have in the illustration?
Old 05-23-2011, 07:32 PM
Yes...Thats the only one listed for the car.....
sorry... the "Location text " box didnt show up.....
The two front ones (1+2) I dont believe interchange with (3)...so look carefully...one of them is still stuck in the case.....
Hmmm... You changed the Solenoid pak and trs...why???? Before you bolt this all up....Find the third piston..and make sure it is free in the Bore....A hanging Accumulator piston can wreak havoc in ALL areas of the trans....
__________________
Old 05-23-2011, 07:34 PM
Default I just checked.
Ok. I just checked under the car and this is it. Now then, out of the two pistons, where do they go. from the illustration on #1, 2, or 3?. What's confusing me that is that it seemed to me that one piston was still kinda hanging from #3 from the illustration when I took down the V/B. So, the other one goes where? #1 or 2?
Old 05-23-2011, 07:49 PM
Default I was getting stuck in limp mode
I changed initially the solenoid pack because i was getting stuck on limp mode and getting codes P1776 and the other P700 or something. And the TRS because the old one got damaged in the process. At least now everything is new.
I was thinking, both pistons I have are exactly the same, they are interchangeable. Perhaps they do go into #1 and 2. Maybe it's my imagination it was stuck around #3. I got a little nervous when the springs came flying out. Actually in #3, there is a piston in there but you can't take it out; there is a ring that holds it in place. That being the case, and since there are no loose parts aside from these. I'm thinking about putting them in #1 and 2 and see what happens. Is that too risky? thanks.
Tags
2004, body, chrysler, concord, concorde, concordes, exploded, pack, solaniod, solenoid, stuck, transmission, underdrive, valve, valves, view
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
