Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Brand Review > Audio/Visual Electronics
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 09-04-2009, 06:58 AM
Default VES Problem Town and Country
I have a 2008 Town and Country. The enterntainment system (DVD player) is displaying "Region Code Not Set". the Disc light flashes when a disc loaded or not loaded.
What is the process to reset the region code? The Remote control "Setup" button is not responding, as the screen will not go away from the error message.
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 09-04-2009, 11:46 AM
Send a message via AIM to CHRYSLER TECH Send a message via Yahoo to CHRYSLER TECH
U will need to visit the dealer to have them set the region
__________________
Dealer trained Tech 15 years Now Proud Owner operator Kevin's Mobile Repair in ATLANTA. Repairing Chrysler,Dodge and Jeep
KKeller608@aol.com
http://kevinsmobilerepair.com
Old 11-11-2009, 01:24 PM
Default DVD region code issue
My wife had the Van in the dealer for a different reason. She asked them to look at it. They returned to say it was the within the DVD player. Cost to say this $89. To replace it would be $250. Currently I think they are hard up for money, played with it for 10 minutes (like I did) and decided they couldnt figure it out, and could get more money by selling a new unit.
Since money is currently tight, she opted not to get it. Although still paying $89 for nothing.
Is there anyway to get the code so I can reset the Region. Thanks.
Old 04-25-2011, 03:41 PM
Unhappy VES - Region Code Error....Is there a simple fix?
I have this same issue...however, convienently, it was immediately AFTER I took my car into the dealer to get everything checked over since my 3y/36K mile warranty was due to expire. (It expired on the 12th, I had my vehicle into the dealer on the 8th) When I got my car back, I noticed the blinking light, however, I wasn't able to take it immediately back into the shop. They now want me to bring it back in, and pay, since my warranty is now over. Which is odd, because it wasn't broken until I took it in. Could it have been jarred loose or disconnected when hooked up to something at the dealer? This is frustrating. I get recall after recall on this van, and now this. I don't need something else needing repair. Very disappointed in the purchase of this van. Seriously, this light was blinking before I even took it off the lot after I had the warranty stuff looked over. That's just NOT RIGHT! Too late in the day to get it checked immediately, but still, why am I having to foot the bill for this?
Old 12-15-2011, 09:39 AM
I'm having a groundhog day regrettable just like yours. Cost me 69 to reset the region code. they said drive it around and if the satellite syncs and it works fine ... otherwise 320 to replace it. will the 69 go towards replacement cost ... nope
what did you end up doing?
Old 12-15-2011, 10:34 AM
TNtech's Avatar
Did you join up just to complain that cars cost money to work on, or do you have a question? We answer questions here. This isn't the Chrysler LLC complaint dept.
__________________
Chrysler-Jeep-Dodge Technician
Electrical & Driveablity
Crossfire
Old 12-15-2011, 01:14 PM
TNtech,
ok, quit complaining and get it fixed ... I read you loud and clear
my question is should I try remove the dvd and repair the region code msg or replace the whole unit? (I see some 'refurbished' units out on the net)
Old 12-23-2011, 03:38 PM
TN tech ... there was a question right in my initial groundhog day reply so not sure how you missed that ... ??
not sure what your gripe was but tried to get a response to 'what did you end up doing?' or a suggestion from the forum
well here's the rest of the story
dealer came back with $849 estimate to replace the lower dvd unit after the region code reset FAILED
so i did a little research and found an outfit that repairs these dvds
United Radio - Quality Electronics Service Since 1923
and Kevin has been very helpful
kmarais@unitedradio.com
to remove the dvd:
look carefully under the dash trim just above the navigation control monitor ... there are two plastic covers you need to pry off... it's like a compression fit that you need to gently pry off and down
remove the 2 philips screws under the covers and gently pry the dash cowling up and out of the way
the trim piece can now be pryed out at the top as there are some slots along the side that provide resistance
however ... the bottom section has two screws that can be revealed by removing the 3 screws on each side of the bottom cowling that covers the lower dash panel (where your feet rest)
pull the lower dash panel out and you'll see the two screws that need to be removed ... now the center dash panel can be slowly pulled out as the wiring harness gives you some room to pull it aside
now you can unscrew the 2 screws actually holding the dvd in place
you will find the dvd still seems screwed in but it's just a compression fitting at the back of the dvd ... gently pull and and wiggle a little straight back and the dvd should release
carefully pull the dvd out and try to guide the wires connected thru the access panel
on the back of the dvd depress the little black tab and the whole wiring harness will release
not sure if this helps but I'm hoping united radio can fix it ... initial quote was 215
Old 12-23-2011, 04:29 PM
I'm making progress ... when are you going to answer my original question ?
Tags
2008, chrsyler, chrysler, country, dvd, error, free, jeep, manual, rear, region, reset, town, user, ves
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
