Seems after two years of trying to figure this out, Oklahoma Wolf over at the turbododge forums has done it (apprently two years ago!). It works on any Infinity I, II, or III head unit with a CD changer plug on it (does not need specific CD controls). They note that newer models have to same type plug, but a different pinout, so this particular method will not work with Infinity IV or newer.
This is an 8 pin DIN connector you can often find at electronics supply stores. Same connector as Alpine uses for M-Bus. Pin 8 must be shorted to ground to mute the tuner/cassette and switch to the connector inputs. I use a switch connected between pins 8 and 3 to do this (you can also ground out pin 8 to the metal connector sleeve itself). The audio input pins are self explanatory - I use pin 2 for the common signal ground.
It's at www(dot)turbododge(dot)com/forums/f4/f21/201929-adding-aux-port-91-infinity-head.html
He includes a pinout diagram of the port in question.
Waiting for my parts to come in so I can *finally* rig this up!
