07 Sebring cruise control not working
Hey everyone,
The dealer tells me I need a new cruise control switch. How would one go about replacing it? I don't have a repair manual. Is it a simple task or is it difficult?
The speed control system is fully and electronically controlled by the Powertrain Control Module (PCM). A cable and a vacuum controlled servo are not used. This is a servo-less system. The switch is labeled: ON/OFF, RES/ACCEL, SET, COAST, and CANCEL.
The speed control switch is mounted in the steering wheel and wired through the clock spring device under the airbag module.
Removal:
1. Remove the negative battery cable.
2. Turn off ignition.
3. Remove air bag.
4. Remove the top mounting screw.
5. Rotate steering wheel so that the switch is in the 6 o'clock position. Remove 2 screws from the back side of the speed control switch.
6. Disconnect the electrical connector.
7. Remove switch.
Installation:
1. Connect the electrical connector.
2. Install switch and tighten the screws to 1.6 N·m (15 ins. lbs.). Make sure rubber seal is in place around switch.
3. Install airbag.
4. Install the negative battery cable.
Removal:
3. Remove air bag.
7. Remove switch.
Installation:
3. Install airbag.
I have a similar but different cruise control problem on my 2008 Sebring Convertible. The cruise will only work at 3 certain speeds, around 40-45, 60-63, and 78-81 MPH.
If for any reason it goes out of those ranges (i.e. going up or down hill), the cruise is turned off. I don't know what to try.
