P0352 code after changing spark plugs
I just changed the plus in my daughters 2001 2.7 tonight and now I have a P0352 code.
I know ht is something up with the coil pac so I switched number 2 with number 4 hoping if the pac was bad, the code would move form cylinder 2 to 4, Disconected the battery while I was switching them and tried again and I stil get the P0352 code for cylinder 2 not 4 like I would have thought. What should I check next?
Never mind. I think they sent me another bad replacement PCM. The original PCM went bad so I ordered a rebuilt PCM from ACE (Auto Computer Exchange) and the first PDM they sent was bad and stil lthrowing a P0601 code. Then sent me a new PCM which I also installed tonight and now it is making the car run rough and have the P0352 code.
To verify this, I plugged the 1st replacement PCM back in and the car started idling ok and the P0352 code was gone but the P0601 was back. When I switched them back, the P0352 came back so it must be in an issue in the PCM. I wil have to call them again tomorrow. This is starting to get old.
ronypal
03-29-2012 06:20 PM
Morris04127
06-28-2010 09:17 AM
