2000 Chrysler Sebring No Spark
Old 08-17-2009, 11:38 PM
mugensi's Avatar
Unhappy 2000 Chrysler Sebring No Spark
My car has fuel pressure, but not spark. I have tried replaicing the distributor, crank sensor, and tried reading the codes. There are no engine codes, and the parts I replaiced didn't bring the spark back. I checked to see if the timing belts are ok and they are fine. I also checked to see if one of the cams was broken, but they are ok too. Any ideas?
Old 08-21-2009, 10:24 PM
Coil? ASD relay?
Old 08-22-2009, 01:58 AM
mugensi's Avatar
The coil is in the distributor that we replaiced. What is a ASD relay?
Old 08-22-2009, 07:52 PM
Auto Shut down. If it's bad you won't go anywhere.
Old 08-22-2009, 09:15 PM
mugensi's Avatar
doesn't the ASD only shut down the fuel pressure? I have fuel pressure, just not spark.
Old 08-23-2009, 10:12 PM
ASD supplies power to the fuel injectors (not the pump), the ignition coils and the heating elements in the oxygen sensors in my 2001 2.7L convertible. I suspect yours is somewhat similar. It's a cheap and easy replacement. Certainly worth a check.
Old 08-24-2009, 10:00 AM
mugensi's Avatar
Thank you! I will try that.
Old 08-24-2009, 10:13 AM
mugensi's Avatar
where is it located in the car?
Old 08-24-2009, 10:46 PM
Check the power distribution center (fuse box) under the hood.
Old 10-14-2010, 03:42 PM
brandys's Avatar
Thumbs up
[quote=dcotter0579;30009]Check the power distribution center (fuse box) under the hood.[/quoti have a 2000 sebring lxi, just had the same problem,changed the distributer cap,cam sensor,fuel filter,then came to this site and seen that you said check asd,[automatic shut down]and that was it,i found it against the firewall on the drivers side in plain site,by the winshield washer tank.
WillQRose
10-18-2018 07:18 PM
austin
Cirrus & Breeze
09-16-2012 09:09 PM
Brandon50394
06-14-2011 12:49 PM
PBrowning
05-17-2011 12:31 AM
saulsorrels
02-27-2011 08:18 PM
Quick Reply: 2000 Chrysler Sebring No Spark
