2000 cr sebring con no spark.
Old 02-26-2011, 11:16 AM
saulsorrels's Avatar
Default 2000 cr sebring con no spark.
I have no spark new plugs and wires new cranck sensor relay and still no spark any ideas?
Old 02-26-2011, 08:35 PM
Distributor or timing belt. Check for codes, check timing belt. Don't just throw parts at it.
Old 02-27-2011, 10:27 AM
Default ok
We put the distruboter on it now the rpms are at 3-4 i will not leave it running the throttle line are hook up right what else can make it not idea it is very high idle now
Old 02-27-2011, 08:18 PM
If the throttle is properly closing (better double check that first) you may have a sizeable vacuum leak. Possibly your idle air control motor is shot. There should be a code for that.
WillQRose
10-18-2018 07:18 PM
Jason1969
07-08-2013 09:35 PM
austin
Cirrus & Breeze
09-16-2012 09:09 PM
PBrowning
05-17-2011 12:31 AM
mugensi
10-14-2010 03:42 PM
Quick Reply: 2000 cr sebring con no spark.
