2001 lxi convertable 2.7
Old 04-06-2013, 02:29 PM
SOSebring's Avatar
Default 2001 lxi convertable 2.7
The car's been running fine, no sign of anything about to happen. One year old interstate battery. Came home, parked the car, locked it just like normal. The next morning, put the key in, turned it, and nothing... no clicking, no ratatat, absolutely nothing.
1. All lights on dash light normal.
2. When I turn the key on, the stereo goes through it's sequence to check for CDs.
3. Moved the shifter from park to neutral and back to park, still nothing.
4. Turned the headlight on to see if they were dim, nope, seem just fine.
5. Pulled the jumper cables out anyway and tried jumping, nothing.
6. The key's not disabled, I've seen this before, there would just be a single dimming and glowing red light, and that's not the case.
Maybe starters just fail out of the blue but they've always seem to give some indication, even in a failed state.
I wish there some sound, at least I'd have a place to start. I'm going to check the fuses after this post.
Thank you for your consideration.
Old 04-06-2013, 11:17 PM
Check the starter relay while you're checking fuses. If that's not the problem, check to see if the ignition switch is working properly.
Old 04-08-2013, 11:55 AM
SOSebring's Avatar
Bad starter/fuel fuse. So much better than a starter : )
jinxracing1
Other
10-26-2013 10:38 PM
Speedvoyager
03-03-2013 08:16 AM
porsch3xx
12-31-2012 11:26 PM
maxsmohr
12-17-2010 10:40 AM
ace
11-18-2005 12:13 AM
Quick Reply: 2001 lxi convertable 2.7
