02 Sebring Convertible, 2.7 doesn't starts.
Hi!
I drove on my 02 Sebring Convertible, 2.7 and the noise shows up... like something touching the FAN (metal noise) I tried to switch transmission from "Drive" to neutral or to parking - everything fine. Dynamic of the car is same as earlier. I came to practice and in 3 hours after practice I've tried to start it, but it doesn't starts. I tried to start it many times, but no result. The car was towed to my apartment. I bought the OBDII scanner and it showed P0700, P0725. I bought new Crankshaft sensor for 15 dollars in AutoZone, took of previous (metal part was out of sensor inside the transmission). Using the screwdriver I very carefully took of the metal part from old sensor and insert new. Then I tried to start the car, but no result (only 5 seconds, because my battery died). I tried to read the codes, but scanner said "No DTC data". Now my battery is charging and tomorrow morning I will try again, but I'm sure it will not start. What else can I try to check and how?
marshall_kristin
03-20-2012 07:29 PM
