2002 sebring doesn`t charge battery - Chrysler Forum - Chrysler Enthusiast Forums
LinkBack Thread Tools Search this Thread
Old 03-30-2011, 11:12 AM
Default 2002 sebring doesn`t charge battery
Hello!
Generator works normal, providing stable power when engine is on. But battery (9 months old) slowly discharges (starter runs slower and slower).
It looks like some relay is broken, which turns battery charge on. Could you please point what is it name?
Thanks,
Sergey
Old 03-30-2011, 12:17 PM
Battery charging is controlled by the engine computer. If the generator is working and providing a charge, it should maintain the battery charge. Check for corrosion on the battery cables, beginning right at the battery and as far as you can check. Another possible problem is a bad battery. If it's only 9 months old, take it back to be checked. It ought to be under warranty.
Old 03-30-2011, 01:30 PM
Thank you for reply, Dcotter0579!
Yes, i`ve checked that voltage is 15 Voltes on battery contacts that means generator works fine, and replaced battery by warranty in PepShop Boys shop, where it has been bought originally.
The only problem is that the $55 labor to replace battery is not under warranty.
The failed battery is a Boshe battery.
Thread Thread Starter Forum Replies Last Post
2011 T&C-- Can U use the USB port on the radio to charge an iPhone? ww4cash New Member Area 1 01-04-2012 09:47 PM
99 sebring jx conv won't charge yorkguy717 Chrysler 200 & Sebring 2 11-14-2011 12:15 PM
98 T&C Freon Charge? Hood Label Missing Diamondssleeper Chrysler Voyager & Town & Country 6 08-14-2011 02:01 AM
$700 labor charge for timing belt & waterpump change..? Raindrop Chrysler Pacifica 8 06-20-2011 10:41 PM
94 T&C wont take AC charge 97LXIgirl Chrysler Voyager & Town & Country 2 06-07-2008 08:12 PM
Tags
02, 2002, 27, 99, bad, battery, charge, charging, chrysler, convertible, normal, runs, sebring, type, volts
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
