2004 Sebring
Old 01-15-2014, 12:49 PM
lbmartin81's Avatar
Default 2004 Sebring
Can't pass inspection this year: my check engine light won't come ON. I hear the 'ding' when the car is started but no light. I have pulled apart the panel and the bulbs are good, disconnected the negative batt terminal and nothing. It is the only one off. Any ideas? ? Thanks so much!
Old 01-16-2014, 10:37 AM
It's not supposed to come on when the car is started. Try this: While holding in the odometer reset button, turn the key from "lock" to "unlock". This should initiate an instrument cluster self test which will test all the lights and gauges in the cluster one by one.
If the light doesn't come on for about 4 seconds during that test, and you're sure the bulb and socket are good, then you're looking at a defect in the cluster itself, the body control module or the powertrain control module.
You'll need to have someone with a DRBIII scan tool figure out where the problem lies.
Old 01-16-2014, 12:53 PM
lbmartin81's Avatar
You rock.. I will try tonight when i get home. Thanks so much!!! You may be my cherry flavored lifesaver of the year!!
dalexx10
05-31-2021 08:51 PM
jeannette27
01-17-2018 07:20 PM
TricksX
03-15-2007 12:54 AM
greeniebfd
12-01-2005 05:10 PM
lvssmr97502
09-03-2005 01:22 PM
Quick Reply: 2004 Sebring
