2004 sebring will not start/battery charged
Could be that the battery is shot and won't hold a charge at all. Could be corroded terminals in the starting circuit won't allow starting current to pass. Could be a blown starter motor. Could be many things. Have you checked for codes? Does it crank but not start? Does it click but not crank? Do other things work, lights, horn, etc?
Thanks for your input following is an update. New battery (old one would not maintain a charge), replaced starter relay-- results nothing changed. Horn works, lights work,top works, does not even attempt to crank. Acting as if the circuit is wide open ?
amk64
06-14-2015 02:09 AM
La_TomboyGirl
03-11-2012 08:04 PM
