2008 conv top stuck
2008 conv top stuck
okay...this seems to be a common problem
top has always worked fine. replaced the top with a new one. cycled the top up and down a number of times and or jogged its position a number of times to facilitate top installation. everything was working fine. a couple of times it would not move , but seemed to fix itself. had a problem with the aluminum seal retainers interfering, but i fixed that. right now the top is almost in the full upright position. about 2 more inches to go. latches open ready to receive the top.the rear deck is not quite in the full tilted back position and the tonneau deck has not retracted. i had i think, a low battery from all the cycling, so charged the battery. turn on the ign and push the rocker switch to raise the top fully and get a top fail. nothing moves. all windows and all else work fine. when the switch is activated, i do not hear the pump run.
help!!!!! my wife needs her car
Drlawgr
12-27-2008 09:41 PM
Justa_Hat_Rack
08-22-2007 07:47 PM
