2010 Sebring A/C and Heater Control Switch
I need to replace the A/C and Heater Control Switch cluster in my 2010 Sebring. Do I have to remove the entire center console or does the plastic trim come off? Is there any walk throughs to help me do this? Any help would be greatly appreciated.
Not sure about your model, but typically, a bezel can be removed by prying it off. In the assembly plant, they want these things to go on very quickly and easily, so they usually are held in place by clips that snap into place with a quick push.
DO NOT attempt to pry it off with a screwdriver. You will damage the plastic part and probably the underlying panel as well.
For less than $10 you can buy a set of plastic trim tools that will be worth their weight in gold. You would also be well advised to buy a manual, such as a Haynes or similar for a detailed explanation of the task.
Manuals are available at most parts stores.
Harbor Freight carries the trim tools.
Dcotter0579 I wanted to thank you for your advice. I got the manual from Haynes, but didn't need it after your post. From your explanation and the manual it was a 10 minute job start to finish.
I had checked several parts houses as well as the dealership and found my part for about $185 plus 2 weeks shipping time. After much research, I found it from RockAuto.com for $108 plus $12 for expedited shipping. I got it in 2 business days. I would recommend them for any future parts issues.
Mitchell201
10-26-2015 01:23 PM
grimlok
10-23-2015 03:29 PM
darkcild101
13
07-30-2015 08:08 AM
