'96 JXI starting problem
Old 05-21-2010, 08:37 AM
Imprl59's Avatar
Default '96 JXI starting problem
So my new to me JXI doesn't want to start.
When I got the car it had a completely flat battery in it. Replaced with new. Second or third start I thought it was spinning a little slow but every time after that has been fine.
Yesterday I replace the broken rear window regulator. After replacing it I get in and turn the key and get "Click" and that's it. I thought I had run the battery down having the interior lights on so I put the charger on it overnight.
Today I get the "click" but if I just hold the key it starts to grunt a little then rrrr rrrr rrr like a dead battery and once it gets a little spin going it ramps up to full crank speed. AutoZone just checked the battery and says it is good and charging system is good. Battery cables are cool to the touch so I don't think I have a bad connection. Before I blow $120 on a starter is there something else I should be looking for?
Steve B.
Old 05-21-2010, 02:50 PM
Look for corrosion in all the connections between the starter and the battery.
Old 06-04-2010, 11:12 AM
Mappleyard's Avatar
Default distributor
It's the distributor. the 1996 model has a problem with them. I am replaceing mine as we speak.
Old 06-05-2010, 07:33 AM
Imprl59's Avatar
It was the starter. Replaced it and it starts right up.
Steve
byteasc
12-22-2013 09:28 AM
bamabeauty81
01-06-2012 05:13 PM
Beware_of_Dog
05-26-2010 06:18 AM
evanjah
12-20-2008 08:08 AM
97jxi
08-25-2007 09:30 PM
Quick Reply: '96 JXI starting problem
