Batt light and its charging fine. Help!
Old 07-28-2013, 05:31 PM
Smb's Avatar
Smb
Smb is offline
Default Batt light and its charging fine. Help!
My wifes 2006 sebring touring 2.7l sfi with 100k on it has it's batt light on. Shut it off and start it again its off but comes back on soon after.
The batt and alt are a couple years old. Eng off ive got 12.5+v at the jump post, running 14.2 ad with every accessory on at idle will drop to 12.4. Live stream obd2 reads similar, 12.9v.
Its parked outside and i live in the woods so critter in the wires? Inspected as best i can and found no chaffing or bare or loose wires.
Cable from alt to jump post has a good ohmm reading.
On startup the engine seems to have a hum to it, but goes away.
No CEL or codes stored, just the batt indicator on the dash.
Readings are all the same whether the hum is there light on or not.
I'm lost as to where to go from here. Any common issues that might cause this??
Old 07-28-2013, 08:36 PM
Never heard of anyone complaining about that particular problem here. That light is called the charging system warning light. It's controlled by the body computer, probably acting on information received from the engine computer. If the thing is bugging you excessively, find a shop with a DRB III code reader. Your personal code reader isn't going to be able to get deep enough into the computer(s) to find out what's going on. A Chrysler dealer will have the necessary equipment but they will charge you like $100 to hook it up and read it. If the problem turns out to be a defect in a computer, you're looking at maybe a grand or more in repairs at the dealer. There may be cheaper alternatives elsewhere.
Disconnecting the battery at the negative jump post MIGHT reset the computers and fix the problem, if that's where it is. It's cheap and easy and won't hurt anything. Leave the battery disconnected for several minutes. That will discharge the whole system.
Kman1971
06-17-2014 12:04 PM
QinteQ
03-27-2012 11:00 AM
nimrod.sixty9
06-15-2011 06:23 PM
jazzypug1
06-30-2009 05:48 PM
zzr7ky
03-27-2009 10:20 PM
Quick Reply: Batt light and its charging fine. Help!
