Bleeding Valve! How do you open it? 2.7L
Old 10-01-2010, 01:06 AM
Lawdog's Avatar
Angry Bleeding Valve! How do you open it? 2.7L
I mean the bleed valve on top of the water outlet housing on the 2006 Sebring Convt. The factory manual says it's "critical" that I open the bleed valve during a coolant refill. But the valve won't budge until it turns together with it's socket in it's plastic housing, ruining the housing. HOW do the dealer techs do it? Any techs out there?
Old 10-01-2010, 10:00 AM
if it turns inside the housing U will need a new housing. 10mm deep socket
Old 10-01-2010, 11:53 AM
Lawdog's Avatar
Thank you, CT. I am using a 10 mm socket. Do you find that you have to try to open a few bleed valves at the parts desk before you find one that will open, or did I just have bad luck on mine? Are there new housings that grip the bushing better than the originals? Is it a mistake to use the Dorman replacement?
Old 10-01-2010, 01:38 PM
The mistake is to turn the bleed screw at all. The system will bleed itself after a few warm-up/cool-down cycles. NEVER touch that damn screw. You are absolutely right that it will spin the insert in the housing, thereby ruining it.
mr wolf
07-09-2011 01:37 PM
jfmerk
05-29-2011 01:44 PM
donnyohs
02-19-2009 08:14 AM
xmanmta
12-22-2008 06:08 PM
paul.siwek
08-10-2007 01:26 PM
Quick Reply: Bleeding Valve! How do you open it? 2.7L
