A/C compressor replace (or just the bearing)
Old 10-27-2014, 04:21 PM
usdollar's Avatar
Default A/C compressor replace (or just the bearing)
Hello all
Thank you in advance for taking the time to help. It is highly needed and appreciated
I have a vibration+noise from the ac compressor. It is not the ac itself but the pulley(bearing).
Unfortunately in Canada the part is 1000$ + labour + tax and that's why i need to repair it myself... with your help, of course
Please tell me:
1. Changing only the bearing, is it doable?
if yes
2. Do i need to empty the cooling liquid(freon) in order to dismantle it?
3. Where can order the new bearing?
4. Is there any video out there that would show the procedure or help in any way?
I have a 2008 convertible Sebring 2.4L LX
Thanks again!
Old 10-28-2014, 01:05 PM
luke892's Avatar
I had the same issue with mine (older model, 2.7L engine)....
money was tight then, and so I just bypassed the compressor by installing
a shorter belt. Not sure how yours is set up, but I'd bet the same temporary solution can be done.
I removed the a/c clutch-pulley just to get more room to work, but left the
system intact until I can replace the compressor.
Most likely, there's a thread here that will give you more guidance if you go this route....also, check the Sebring Convertible Club website for help
Redirect
Old 10-29-2014, 07:51 PM
Theoretically, it's possible to replace the clutch without opening the system, thus making it unnecessary to replace the refrigerant. You might not be able to find a clutch on the market, and some special tools are going to be required.
Alternatively, you can take it to an A/C repair shop and have them evacuate the system, then you could replace the entire compressor and clutch assembly, then take it back to the shop and have them properly refill the system. You might want to invest in a shop manual of some kind to see what the job entails and determine if you and your toolbox are up to it.
Old 10-29-2014, 10:39 PM
usdollar's Avatar
Thanks a lot !
I'll try and I'll get back with the results
Old 11-05-2016, 11:12 AM
ericm77's Avatar
could you possibly tell me how you found the length of the belt you used and what else if anything needs to be done to make this happen
Old 11-05-2016, 01:22 PM
Eric,
Rather than trying to wake up a two-year-old thread, it would be better to start your own new thread about your specific problem. Tell us what your problem is and what you have done to try to solve it so far. Include pertinent background information like model, mileage, engine size, etc.
Matthew Carns
12-05-2014 01:48 AM
j dog
09-22-2013 12:01 PM
Naison
01-22-2009 02:36 PM
petey1972
04-06-2007 01:28 AM
OldSchool
01-28-2007 01:44 PM
Quick Reply: A/C compressor replace (or just the bearing)
