A/C Relay location
A/C Relay location
Where the heck is the A/C Relay located at on a 2008 Chrysler Sebring? I found 4 Relays under the hood above the fuse box but I have no idea which ones are which or if there are more Relays located somewhere else. I have searched the internet to no avail. Any help would be greatly appreciated.
Usually you can get enough pressure in there to get the compressor to kick in just by connecting the can. May need to turn it upside down and warm the can with your hands a little to dump some fluid in there. If you're that low you've probably got a leak somewhere so you'll just be wasting time and refrigerant by adding refrigerant without dealing with the leak.
You might get a response if you told us what kind of car you have, year, model, engine and mileage. You might want to describe the history of the problem and what you have done to try to fix it. You might want to start a new thread with the necessary information rather than jumping into a 5 year old thread.
andyb2000
07-19-2011 08:38 AM
rastoma
06-08-2011 08:05 PM
