1999 Sebring transmission problem
Old 09-29-2009, 10:20 AM
don_worrell's Avatar
Default 1999 Sebring transmission problem
Hello.
My car runs fine most of the time however sometimes the check engine light will come on and then it will not shift. I can be in any gear and it will just stay in that gear until I stop and kill it which seems to reset it and it work fine. I will then drive for awhile and the check engine light goes off. It does it very sporadically and usually drives very good. I have had the codes checked when it was on and the codes are P034, p1776
Old 09-29-2009, 01:00 PM
sounds a like a solenoid pack to me.
Old 09-29-2009, 01:09 PM
When was the last time you changed the fluid in the transmission? Most transmission problems can be related directly or indirectly to the fluid. It should be changed every 60,000 miles or so. Use only the fluid that Chrysler recommends for your car.
Trouble code table: http://www.2carpros.com/kpages/diagn...uble_codes.htm
Old 09-30-2009, 08:07 AM
I changed the filter yesterday, and have a new input speed sensor to put it (just have to get a wrench big enough). I have driven it about 40 miles since changing the fluids and it hasn't done it again yet. I will drive it more today and let you know. thanks.
Old 09-30-2009, 08:19 AM
ManuteSwol's Avatar
Just curious -- How many miles are on the vehicle?
Old 10-01-2009, 06:43 AM
117k.
Ok it hasn't done this since changing fluid and filter however if i get on the gas and make it go to a higher RPM before changing gears I hear a ssspppp coming from the transmission.
jminter
07-03-2019 10:14 AM
tom66
02-19-2014 06:35 AM
crazymanrols
05-05-2013 04:35 AM
dmschuler
01-05-2011 09:23 AM
shawnkh2003
06-14-2007 04:22 PM
Quick Reply: 1999 Sebring transmission problem
