2001 chrysler sebring lx rear turn signal lights not working
my front turn signal lights work fine but the rear turn signal lights do not work
at all. ive checked the bulbs and they are not burned out no corrosion on the
wires either. if anybody has a clue how to fix this or steer me in the right
direction your help will be greatly appreciated.
Any ground wire you can find back there going to the lights. Follow it all the way to where it grounds on the body. Loosen the screw, wiggle the wire to break up any corrosion and re-tighten the screw.
It's not going to be a relay or fuse problem because the fronts are controlled by the same device.
swittie
11-10-2020 02:02 PM
dckazi
01-15-2010 06:21 AM
chitown18th
12-06-2007 03:26 PM
GSKI
13
09-11-2007 09:33 AM
