Sebring 2004 PCM pinouts & injector contril circuit
Old 01-05-2014, 10:56 PM
Tanveer Hoque's Avatar
Exclamation Sebring 2004 PCM pinouts & injector contril circuit
Hi, I have a sebring 2004 2.7L V6 with P0202 code which means the Injector #2 doesn't fire. I have checked the wires and ASD relay is fine. The last thing I need to do is to check the injector driver inside the PCM. Here are the snaps of the PCM circuitry.
Can someone please tell me the pinouts for injector drivers and if known, which transistor is the driver for injector #2 here ?
Old 01-05-2014, 10:58 PM
here is the link for those pictures-
https://www.dropbox.com/sh/bolcru4u6pif805/WJLfWyZCuk
Old 01-06-2014, 08:39 AM
You can find pinouts in the factory shop manual. They come up every once in a while on eBay.
Have you determined that the injector itself is not to blame?
Old 01-06-2014, 04:44 PM
Hi, yes i've checked all the injectors and they are all working at 100%. Switched to another cylinder position as well to make sure.
Old 01-06-2014, 08:33 PM
your not gonna get any one on here to give u the circuits of the PCM its a propitiatory system unless U have a shop that Chrysler sells the software to and can remain the computers no one has such info for the insides of the PCM.
Old 11-30-2014, 11:22 PM
Robert Pickering's Avatar
did you find out what it was?
ruger1944
03-25-2015 03:14 PM
Alex Eremia
02-07-2015 11:35 PM
davekro
02-28-2014 06:49 PM
teckman02
05-17-2012 08:53 PM
schico
05-11-2009 02:24 PM
Quick Reply: Sebring 2004 PCM pinouts & injector contril circuit
