driver window
Old 12-30-2014, 12:28 PM
metalman3's Avatar
Default driver window
my driver window will not return to the full up position automatically when closing door. this is on a seibring convertable 2008. is this something easey enough for me to fix?
thanks
Old 12-30-2014, 05:47 PM
metalman3's Avatar
Default window
follow up question.....how do you remove the window switch panel? there is a screw under the hand grip and 2 screws under an access tab in the hand grip area, but upon removal, it still won't let go. any help? thanks
Old 12-31-2014, 03:29 PM
Not sure about your '08, but the usual thing for access to the switch panel is to remove the entire door trim panel. Get yourself a set of plastic trim tools before you tackle that job. They're cheap and worth their weight in gold. You might want to think about investing in a shop manual. Then you can read up before you start a repair job and then you can decide if you and your toolbox are up to the task.
Old 12-31-2014, 06:36 PM
metalman3's Avatar
thanks for your response.........i've decided to have the dealer look at it.
cheers
BruceW
18
12-10-2010 05:19 PM
fkthomas
08-31-2008 06:46 PM
rxhinojo
07-26-2008 04:52 AM
davet
08-11-2007 04:17 PM
69roadrunner
08-06-2007 01:12 PM
Quick Reply: driver window
