Heater Problem 2001 Chrysler Sebring LXI Coupe
For some reason my heater is only blowing cold air. I check the hoses running to the heater core through the fire wall, they both are hot. The coolant level is full. I took a part of the dash off to access the controller unit, the tempature **** seems to be controlled by a wire connected to the control **** and seems to be working, you can hear the door moving. Any suggestion other than what I have checked?
My only other suggestion would be to check all the solders on the pins for the controller unit. A hairline crack in a solder could make the unit not work, but not be very visible. But when that happened to me, the air would only blow out of the top defrost. Since you didn't mention that symptom, probably isn't the answer.
MRR
MRR
denn3.0v6
10-01-2012 12:27 PM
spalma09
12-03-2010 09:09 PM
abe2485
09-08-2010 06:29 PM
