help with problem Please.....
I have a 2000 sebring conv. i was running low on gas it started kinda chugging then check engine light came on, had codes read it said misfire on every cylinder and random misfire, egr valve, and coolant sensor any suggestions or ideas??
Did you fill it up and see if it continued "chugging"? You are likely to get some random missing as you are running out of gas. It's also conceivable that in a 15 year-old car, you have some sediment at the bottom of the tank. That might be now clogging the fuel filter. If the problem persists, consider removing and cleaning the tank and replacing the filter that is in the tank.
wheels
03-24-2008 04:58 PM
baseballchris05
05-07-2007 09:52 AM
Boomers00
02-05-2007 09:26 PM
