unusual heat readings.
Old 04-20-2011, 06:00 AM
Laimon's Avatar
Default unusual heat readings.
gents,
today a problem started while engaging AC to my sebring 04 2.7L sedan.
unusual heat, almost at middle of gage, but engine not overheating. ( I have this car for 2 years, heat gage is always at quarter)
6 month ago i replaced head gaskates, water pump, thermostat and water outlet housing..
Fans are working good at both speeds.
note that this happens only when ac is engaged.
any ideas?
Old 04-21-2011, 11:10 AM
United1's Avatar
I would look at coolant flow, leaning towards a partially blocked heater core or radiator. Seems like under a heavy load (AC on) that circulation may not be enough for sufficient cooling, but enough to where it does not overheat. Have you checked (flow, radiator, core) or done a good flush?
Old 04-22-2011, 03:35 AM
Laimon's Avatar
Problem solved by washing radiator, fins where dirty.
later i will drain and clean cooling system, summer has started and must be prepared..
thanks for help
Fress
11-19-2013 03:52 PM
skid2964
10-28-2012 08:07 PM
orandaberg
10-08-2011 09:50 AM
voyager_dan
09-12-2011 05:13 PM
huasi87
04-08-2010 08:53 PM
Quick Reply: unusual heat readings.
