oil leak
Old 08-09-2016, 07:23 PM
dougieg74@gmail.com's Avatar
Default oil leak
I have a 2005 sebring with the dreaded 2.4L. Recently I had timing belt and water pump replaced. Car didn't leak a drop of oil before. Now I dump oil in daily. It doesn't leak while sitting but only while running. Any suggestions? Help please .
Old 08-09-2016, 07:50 PM
05sebringconv's Avatar
Front timing chain cover or oil pan.... you need to get under it and verify where the oil is comming from.
Looks like whoever did the work got a bad gasket or didnt install it properly
Old 08-10-2016, 08:43 PM
2.4 does not have a timing chain nore a timing chain cover that holds oil back. Did the people that put the timing belt and water pump replace the cam seals if they did then thats where the issue is at thats the only oil location on that car that would be messed with doing a timing belt job take it back to them let them redo it.
Old 08-13-2016, 08:55 AM
Sorry my bad, misread 2.4 thought it was 2.7....
Old 08-15-2016, 12:14 AM
all good only .3 engine off lol
milesy_boy
11
11-19-2009 05:34 PM
garr5859
08-21-2007 11:51 PM
Hightechman89
Cirrus & Breeze
03-26-2007 11:12 PM
jason1
11-09-2006 05:28 PM
Cat
03-01-2006 08:25 PM
Quick Reply: oil leak
