P 452 Code
Well CEL is back on again. Got a new Factory Gas cap on Friday So waiting to see if Light goes out. Looking at the Vapor Canister Purge Solenoid next to switch out that is located under Air Box. If the CEL doesn't go out on it's own after a while. Haven't had a chance to look at a hoses and lines just to make sure nothing is broke off or come loose.
Well back again with the CEL on. Installed new purge solenoid. Used Scan tool to clear code and three starts later the light is back on. So looks like might be looking at dropping tank to fix problem, NVLD valve and canister.
This won't help much as it's directed to Chrysler technicians who have access to the technical database:
On the other hand, the pump itself could probably be replaced for less than the diagnosis fee at the dealership.
