P765
There's a solenoid pack on the front face of the transmission that is usually visible and accessible from above after removing the air cleaner box. Search the forum here for several threads discussing it. It's a relatively easy DIY repair. The part is widely sold.
Still TCM issues
Got rid of the last code but I can't get rid of an "old" one....what turns on the "Service engine soon" light, not the "Check engine light", and how do you get rid of it? I keep getting "solenoid malfunction" lights but the solenoid pack has been replaced and the connectors were cleaned with contact cleaner and the codes went away for a while but came back a short time later. I can disconnect the battery and everything is O.K. but then the "solenoid" codes come right back and .......the same over and over!!!! HELP!!!!
Thanks,
RSAIII
Thanks,
RSAIII
Check engine light, service enginge soon light, malfunction indicator light. They're the same thing. Get the codes, find out what is wrong, get it fixed.
Check Engine Light | Resetting Check Engine Light | Service Engine Soon Light | RepairTrust.com
