passenger door latch problem 2010 sedan
Old 01-09-2014, 04:53 PM
roundyround's Avatar
Default passenger door latch problem 2010 sedan
The door wont open on the passenger side front. The inner or outer handle won't operate the door. To take door panel off I need to open the door first, any ideas how to do this? The lock pops up when inner handle is pulled and outer handle seems to be moving linkage but nothing happens.
Old 01-09-2014, 05:40 PM
Where are you? Are you located in an area where the door may have frozen shut from the cold? If so, let it warm up and try it again.
Old 01-10-2014, 06:03 AM
no it isn't frozen now, it has been sitting in heated area for 24 hours. Is this a common problem or I'm I just lucky?
Old 01-10-2014, 10:40 AM
Resolution of the problem: Not pretty, but got door open. Rolled down window, removed window weather stripping by brute force, wedged glass to outside of the door. Then took long screw driver and carefully broke plastic latch assy apart until door popped open. Not for the faint of heart.
Old 01-10-2014, 02:26 PM
AnthemBassMan's Avatar
Location: T-County, Ohio. Good ol' farm country! Or at least what's left of it...
-My '10 Sebring is parked outside year round. Even a couple days ago here it was -11* with a windchill of -31*. My doors opened just fine, except for a small tug to get the rubber seal to break free. Never ran into that problem.
L8R,
Matt
Old 01-10-2014, 04:48 PM
It isn't merely cold weather that freezes doors shut. It's a combination of wet weather (or a car wash) followed by a fast freeze. One approach is a pan of hot water poured around the edge of the door. You can also (carefully but forcefully) press in around the edges of the door to flex the weatherstrip and crack the ice.
provench
10-07-2021 04:42 PM
jquinones
04-08-2008 09:58 PM
mbar
12-01-2007 11:13 PM
joeuc23
10-28-2007 11:10 AM
chase950
Cirrus & Breeze
09-23-2007 12:15 PM
Quick Reply: passenger door latch problem 2010 sedan
