Removing Connector From Brake Light Switch (2010 Sebring)
Anyone know how to remove this type of connector from the brake light switch? I've tried just about everything at this point. Sheer force alone doesn't work. There has to be some type of release mechanism I'm not seeing that allows it to disconnect. I've already tried messing with the various green tabs without any luck.
Do you have a pic of the other side? I think there's a lock that you have to slide back before trying to disconnect the wiring harness. It should be on the backside of the black piece. Then squeeze a small tab while pulling up on the grey part of the harness.
L8R,
Matt
L8R,
Matt
There's nothing on the back side of the black part of the switch unfortunately. Nor is there any discernable tab anywhere that can be squeezed. Other than the green tabs on the front, which I've already messed with extensively. Whatever the trick is I imagine has to do with them. I'm just not sure exactly what it requires.
4everrunning
06-04-2019 11:30 AM
